Ok, well i need some help with this. The power supply that im buying is sleved but not all the way. it cuts off at a point as shown in the picture below. I was wondering what can i use to cover those stupid colored wires. Maybe black electric tape or something? Give me some ideas :)
thanks
I love the look of clean computers and i want mine to look as clean as possible
[IMG]http://i46.tinypic.com/28arssw.jpg[/IMG]
My suggestion would be to buy some cable sleeving, it cost next to nothing if you look hard enough and it looks FRIGGEN AUWSOMME!
If you dont want to do that, your Idea of electrical tape is good.
P.S. Nice build!
There is a tool to remove the wiring and connector from the harness block. Get your hands on one and some small heat shrink. This will allow you to cover each wire independently and still have the flexibility needed to reinstall the wirers into the block. Electrical tape sucks as it is sticky after a while when it comes off.
