Wireless router suggestions?
So I signed up for Fios a while back, and because of the layout of my house, the wireless router had to be placed on the opposite side of my house as my main PC / laptop.
The reception in my room is ok, but I get lag spikes, and disconnects some times.
I tried using some 'power line adapters'   but they have like a 6+ms ping to the router, and will randomly get very bad connection for hours at a time.
...anyway, The router they gave me was a Wireless G single antenna, and they offer an upgrade to a wireless N router for $70, would it be better for me just to go buy a router online? or would it be best to stick with the one fios provided?
for a new router, Ideally I'd like to spend around $50  but no more then $70, and I'd need to be able to
set it up so the fios router gives out the IP addresses, and I'll need to be able to still port forward (to a device on wifi)
and connect to my raspPI that is plugged into the Ethernet port of the fios router. It's about 30ft away, with a wall in between.
Would this be possible with a ~$50 router
Are those problems common with the default 'free' routers Verizon give out?
