My family is looking to get a new router. We currently are using one given by are ISP (it’s a virgin media super hub VMDG480 (its made by netgear))
I have been looking to get a new one as the speed is bad and the connection drops. Also we have a number of devices spread about the house and the signal isn’t very strong for them.
We have four phones connected , three pc’s as well as two televisions.We have other devices but they are used not on as frequently ( tablets and internet radio) .
We seriously need a upgrade as I’m planning too start gaming more seriously in the and don’t want to have to resort to buying a power line adapter to get a good connection.
The budget is around £70.But I’ll consider recommendations that cost more or less. I have already been looking at: Asus RT-N66U and Asus RT-N56U
Also I have just seen that the ISP has a new router we can get, specs: Full DOCSIS 3.0 cable modem functionality (also fully compatible with DOCSIS 1.0, 1.1, 2.0)
Eight bonded downstreams
Four bonded upstreams
Four ethernet 10/100/1000BaseT ports
Wireless b, g, n capable in 2.4GHz band plus wireless a, n & ac in 5GHz band (Dual-concurrent frequencies)
Five internal antennas
Up to three spatial streams in the 5GHz band
Supports WEP/WPA/WPA2 wireless security encryption
Supports WPS push button synchronisation
Built-in router, DHCP and firewall which can be customised and deactivated
Virgin Media customised housing
External power supply (12v 1.5A)
Dimensions: 215 x 70 x 195mm (8.5 x 2.75 x 7.5in)
Is it still worth buying one or should I just take the router upgrade from the ISP
Many thanks for your help.
