Hi there,
I am currently on holiday and I have my bananapi with me and I was wondering if there was an application that when a new Wifi network is detected it will log it to a text file with its strength, lat long and name. Is this possible?
Yeah should definitly possible.
I know some kind of programm that shows Wifi networks in your range:
http://br1.einfach.org/tech/horst/
But I don't know if it supports loggin.
I assume you mean wardriving? Take a look at these:
http://wardrivingonline.com/equipment/linux/software.htm
http://www.wardriving.com/code.php
If you install Android onto your Pi you could use
https://play.google.com/store/apps/details?id=net.wigle.wigleandroid&hl=en
