I am in dire need of some help. I recently moved from somewhere that I had the router and modem set up in my room, and I had my internet running by LAN to my PC straight from the router. I moved into a new home, and I am in a situatuion where the modem and router will not be in the same room as my PC, I am in need of a wireless internet adapter.
The modem is currently in our living room, and my dad plans on drilling a hole through the floor, and setting up our AirPort Extreme in our basement (where my room with my PC is at) and I am not going to be close enough to use a wired connection to it. I may be able to do a wire connection, but I don't want to go through all the trouble of wiring it 30 meters, give or take a few, from the basement den, to my bedroom.
I am currently deciding on what kind of wireless adapter to get, I have the room in my PC for a PCI or PCI Excpress Intsernet Adapter, or a USB adapter. I have no idea which to get, and don't even know where to begin to choose which one I'll get.
I talked with one of my friends and he currently, and has had for the past year, has this adapter, http://www.newegg.com/Product/Product.aspx?Item=N82E16833315096 , in his system and it has worked well for him. I don't know if this would be good or bad in my situatuion, and that is why I have turned to the TekSyndicate community. I'm not looking to spend anywhere north of $40, as I have other things I need to fix in my PC, and new stuff to buy. Any help would be greatly appreciated.
UPDATE!
I finally decided on a wireless reciever, I picked up the Intel Centrio Advanced N6205 from Amazon for $34.
Link Below
http://www.amazon.com/gp/product/B007ZWL4A6/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1&tag=amaflink-20
Any advice on how to set it up would be nice, my PC specs are on my profile.
