Wireless cards
Anyone know of some good wireless cards....not usb...but directly connected to the mobo that can support 100/1000 speeds.
Hy... If you want high transfer speed in your home network you should get an AC router and an AC pci-e wireless card, that's the fastest protocol. It's going to cost you though. An average N wireless pci-e card with a N300 router can get you about 100Mbs at short distances for infranetwork transfers...
As for brands, they're pretty much all the same under the 70€ mark, with an average expense of 35€ for tp-link and such that will do the job well.
If you want 'exotic', get an ASUS AC triband pci-e card.
PCI-E connection is the best option.
