my TP Link ‘TL-WDWN4800’ doesnt work on Linux when its plugged in to an pcie-lane from the chipset.
I am using the x370 Gaming 5 from Gigabyte. it does work on Windows and it shows up in bios. But once i boot into Linux i cant see the pcie-device (tried lspci etc). Once i plug the card into an pcie-lane directly from the cpu i can see the wifi card + i can connect to my wifi-network just fine on Linux. I am using the latest kernel as well.
Any ideas what causes this ?
Thanks in advance!
Ps: I dnt want the card to run over cpu-pcie lanes because this will cause my gpu to run on pcie 2.0 on just 4 lanes.
In the cpu-pcie-slot the card is working just fine. So the driver/kernel is able to work with this card. The problem only occurs when the card is in the chipset-pcie-slot +Linux.
I am talking about the x370 chipset, which handles most of the input/output on my mainboard. It also handles some pcie lanes.
Directly connected to the cpu are: GPU (16 lanes) and nvme m.2 ssd (4 pcie lanes).
The x370 chipset handles all other pcie lanes on my mainboard and is connected with 4 pcie-lanes directly to the cpu.
My mainboard has the option to only use 4 pcie lanes directly from the cpu for the gpu and provide another 4 pcie lanes directly from the cpu if the second x16 slot is populated. So when i use that to connect the card directly to the cpu, everything is fine. But that slows my gpu heavily.
The x370 connected pcie slots are also not broken since they work on windows just fine.
