The very quick and dirty way to do WDS which works fine out of the box:
Master node/AP
- Connect device network to any of the LAN ports
- Install image with wpad-openssl or another “full” wpad package (nano is also nice to have)
- Disable WAN and WAN6 interfaces in /etc/config/network
- Adjust IP-address, set gateway and dns for LAN interface in /etc/config/network
- Setup timezone (optional, needs package) and ntp server in /etc/config/system
- Setup wireless networks (ssid, keys, wpa2/3 etc)
Addoption wds '1'to the network that’s going to be linked using WDS - Reboot, done
Example:
config wifi-device 'radio0'
option type 'mac80211'
option path '1a143000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0'
option channel '52'
option band '5g'
option htmode 'VHT80'
option country 'DE'
config wifi-iface 'default_radio0'
option device 'radio0'
option network 'lan'
option mode 'ap'
option ssid 'Foonet-LNK'
option encryption 'sae'
option key 'MySecretKeyGoesHERE'
option wds '1'
Client node/AP
- Configure one radio to act as “link” (this will be dedicated), the other as AP as default
Don’t forget to addoption wds '1'to the “client link” radio - Reboot, done
Example:
option channel '52'
option band '5g'
option country 'DE'
option mode 'sta'
option wds '1'
Now all LAN ports will connect to your network and act as a switch and wireless bridge on your “Client node/AP”
Edit: You can also make WAN port available but that may also render the device unreachable if you’re care so I usually leave it alone as 3-4 ports are usually enough anyway.
Short version of: [OpenWrt Wiki] Wireless Access Point (aka "Dumb" Access Point)
