Wireless audio, the least of the bad
I have no problem middle of the road budget wired headphones, but Id be willing to pay premium if there was such a thing as accetable wireless audio / headphone performance.  Can you recommend any? Thanks, id advance, for your time.
I do believe sennheiser has a wireless headphone set. A couple of varying priced models
I don't know much about wireless headphones myself, but I've heard that Sennheiser makes good ones. You can read up on the ones that fit your price range the best on head-fi (plenty of revies available there for most headphones). I would suggest that you reconsider wireless. Extension cables have always worked for me just fine for the most part. That and my main headphones (Q701) come with a 10' and a 20' cable, which is plenty for me. If you are set on wireless though, there are some options available.
Just search the forum, there is a lot of recomendations already about wireless headphones
