Wireless adapters
What are some good wireless N wifi adapters? My friend thought this was good -> http://wireless-adapter-review.toptenreviews.com/cisco-linksys-ae1000-review.html
What do you guys think?
                                                     -Chris
My vote goes to Intel's adapters, I have 2 of them (7260 ac version and an Ultimate N 633anhmw). They are a little bit pricey compared to others but they work extremely well.
Almost any half decent wireless adapter will work.  I have a TP-Link TL-WN722N which is pretty cheap, and works pretty well.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704045
At that price, I think you should be looking to find some wireless adapters that also have a/ac capability.
The linksys adapter seems a bit pricy for Wireless N, even though it is dual band. I think there is a newer model of the same one from Linksys. AE2500 and AE3000. Check them out and check prices too.
TP Link have a few different models. The one I have is N300, but is only single band (2.4Ghz) even though it is Wireless N. It's ok (and not pricey), but I should have opted for the N600 (has both bands 2.4Ghz and 5Ghz at 300Mbps each) as we have a lot of wireless devices at home and I like to dedicate the 5Ghz band just for streaming video/music. It still works very well and I can stream video fine from my laptop to the rest of my network at that rate.
http://www.amazon.com/TP-LINK-TL-WDN3200-Wireless-Adapter-One-Button/dp/B007ZWL1ZE/ref=dp_ob_title_ce
Don't know if you're into Linux but people say this works really good in Windows and Linux. Alfa Networks AWUSO36NHA
Thanks Guys!
