dose ms office 365 work well in wine?
if now is there a better way to install it?
but if it does how do i install it?
(Yes i do already use LibreOffice)
No idea how well it runs, but to install you just
wine ./OFFICESETUP.EXE
You should really give LibreOffice a shot. It does what 99% of people need their Office suite to do.
Lol, looks like they're doing browser filtering. You'll have to spoof your user agent.
iv done that (using "Mozilla/5.0 (Windows NT 6.1; WOW64; rv:40.0) Gecko/20100101 Firefox/40.1") and downloaded a and downloaded the install file (called "Setup.X86.en-US_O365ProPlusRetail_eac4b961-9387-4053-92cd-0954a84b96d8_TX_PR_.exe") bit it just gives me this:
Looks like it's not compatible.
i recommend to take a look at Crossower, i belive with Crossower you are able to run MS Office 365. Check out the Website best of Luck!!'
You have a free trial, check it out.
best regards.
