Win7 install help
I am getting this messege when I try installing Win7 to my Vertex 3 120GB. This drive was just being used in another pc so I know its good.
"The selected disk has an MBR partition table. On EFi systems, Windows can only be installed to GPT disk"
First, how did this happen?
How do I fix this?
Thanks for any help
why not format it to a GPT disk?
How do I do that? ive never had to do that
during the install select advance setup or something and reformat the drive
http://windows.microsoft.com/en-us/windows/installing-reinstalling-windows#1TC=windows-7
I reformatted and the same thing
http://technet.microsoft.com/en-us/library/dn336946.aspx
good luck
Thanks!!!! Im rolling now, and I learned something :)
