Will you guys look over my friend's build? Thanks
So... How should I start this post?
Well, I have a friend who wants to start YouTube-ing, so I told him the best way to get a computer for editing and gaming is to build one. This way it's made to his needs (quick rendering, smooth frames, generally fast, ect.)
Before I could help him pick some parts he came to me with this list:
BTW his budget is around $800.
MOBO: MSI 760GM-E51
Case: Corsair Carbide series 300R Black
CPU: AMD FX-8350
PSU: Corsair Builder series 430W
HDD: WD 1TB 7600RPM
RAM: Kingston Hyper X Blu 8GB (2x4GB)
GPU: Radeon HD7750 2GB GDDR3
OPD: Samsung Optical Drive CD/DVDR
FAN: Corsair Air Series AF120
OS: Windows 7 Home Premium
I think it's a pretty solid build, but before I give him the OK to get the parts at the end of this month, I just need a little assurance. This is the first build he has done, and I think this would be a good start.
Oh and also he seems pretty set on the FX-8350, I thought he would have gone with an i5, but he likes AMD.
Thanks for the help,
Alek.
Here is the parts on PCPartPicker: The website is being stupid, I'll put it up, as soon as I can.
The build looks pretty good except for the graphics card.  The 7750 is most definitely the bottleneck of the system, because It's a low end card.  I would at least go with something like a GTX 760/R9 270x
put into pcpartpicker.com or it didn't happen
it makes it easier to help you
I would get an 8320 and use the money saved to put it in a board like this one or I would just pay the bit extra. I wouldn't want to stick a fx 8 core on a board much cheaper then one of the better 970s.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128651
http://pcpartpicker.com/p/2wX3o
Had to change the case to fit the budget, but the NZXT Source 210 is still a really nice case with good cable management, good airflow, and plenty of room for all the components, plus a cutout for the aftermarket cooler.
8320 instead of the 8350 to help fit the budget and it can easily be overclocked to match the performance of the 8350.
Much better motherboard with better support for the 8 core processor.
Slightly better PSU for more upgradeability.
Much better GPU. R9 270 will kick the pants off of that 7750.
With the Hyper 212 Evo CPU cooler, extra case fans shouldn't be needed, but can be added later if desired.
Try something like this:
http://pcpartpicker.com/p/2wX5H
It's a little over budget, but it's definitely worth it. One thing I would like to mention is: no matter what you build, you're going to want at least two HDDs. Use one for your OS and games, and then use the other for recording games. If you try to game and record on the same drive, you're going to experience lag and other nuisances.
Very close to my recommendation.  I'll take your suggestion one step farther and say that if you're going to get a second hard drive, you might as well get a solid state to increase performance.
http://pcpartpicker.com/p/2wXpe
A 120 GB SSD should be enough to store the OS and whichever game you'll be recording/streaming.
This is assuming, of course, that you have a copy of Windows that you can use/re-use.
Meh, I personally wouldn't bother with a SSD. It's definitely something to consider, but at a $800 budget, a SSD would be pushing it. I would just get two 1TB HDDs and call it a day. They are plenty fast, and you get more storage for your money. The only performance enhancements SSDs offer are decreased load times, which honestly aren't all that important. Most people leave their PCs on. This allows the user to take advantage of caching, which is plenty fast.
I strongly disagree... a 120GB Kingston SSDNow is $70 @ Amazon... which is like $10-15 more than a decent 7200RPM 1TB HDD... It's not just faster, it's a LOT faster at data transfer and loading times, and they are nearly 100% failure proof... for boot times and core programs they're fantastic.
Besides that, 1TB is a lot to fill up... if you need something 2 years from now for storage it's easy to throw in another HDD... However it's a bit of a pain in the ass to have to format a HDD to take the OS off of it and reload Windows on an SSD should you ever upgrade later...
+1 to any motherboard improvements. You cannot simply throw the 8350 on any given AM3+ motherboard.
+1
I would go with at least an M5A97 R2.0.  Preferably the M5A99FX Pro R2.0, though.
I'd get a FM2 A78/88 board and a Athlon 760k along with a GTX760 rather than that.
