Hey,
Planning on setting up a custom water cooling loop soon, and I was wondering if this is the best way to run my tubing. Any suggestions are greatly appreciated.
http://gyazo.com/f035d1af23bfdb5f75667b19a1aef976
Thanks!
Big Big Ron
Hey,
Thanks!
Big Big Ron
In my opinion it looks like a lot of radiator for what you are cooling (one CPU, one GPU). You should be able to run the fans at a low RPM, so that will be nice. If you can kill the 120, it will help lower the complexity of the loop a little. Personally, I am able to cool 2 GTX 680 Classifieds (stock clock) and a 3930k @ 4.2Ghz with a 480mm rad. What CPU and GPU are you going with?
My CPU is an FX 8350, and the GPU will be an R9 290x. So would you recommend using only the 360mm and a 240mm radiators?
That is what I would do. That 120 in my opinion isn't going to do anything for you except cost more and make the loop harder to create. I think you have a great setup no matter what you do! Is this your first watercooling setup? They are fun, aren't they?
