Will This work?
OK so i am wondering if this mobo will work with this proccesor.  I know they r compatible but will the mobo be able to handle this?  If u reccomend a mobo, plz keep it around the same price.  Thanks!
CPU: fx 6300
MOBO:MSI 970A-G46 ATX AM3+
This should be in the Motherboard section not the "Build A PC" section, anyways it will be able to handle it but if you have a case with USB3 then the USB3 won't work because the motherboard doesn't have a USB3 header.
Moved to Motherboards, an yes, it will work.
i would recommend Asus M5A97 R2.0 a much better board then this msi board. better powerphase, and better vrm´s better overclockability.
