Total: $650.16
Will this moderate gaming such as gta IV. My computer teacher is giving me windows 7 64-bit.
Total: $650.16
It will work okay but I highly suggest you get at least a 650 ti. I also noticed you only grabbed a single stick of RAM. Make it a 2x4gb config for the faster dual channel setup.
* PSU is NOT a good one so stay away from that one.
* RAM is seperate sets, which isn't the best idea to do. You should get matched sets (Dual Channel) and 16 gb's of RAM is a bit much for most needs, so I'd suggest getting 8 gb's (2 x 4 gb matched sets). Also make sure you use LOW PROFILE heat spreader heatsinks, so you can add an aftermarket cooler to your setup without any clearance issues.
* Mobo doesn't support front USB 3.0 ports for a case, so I've listed one below that does and one that doesn't break the bank.
* Case is okay, but w/$30 in fans causes your case/fan combo up to $75. I have a good cooling case below that is good out of the blocks for ~$50! It also has 2 x USB 3.0 ports too! You'll thank me later for that option!
* I also noticed that you didn't include a DVD drive, was that the plan?
* My build below includes a better GPU and all of the aforementioned issues listed above, just add your monitor and accessories to the build.
[url=http://pcpartpicker.com/p/RR0n]PCPartPicker part list[/url] / [url=http://pcpartpicker.com/p/RR0n/by_merchant/]Price breakdown by merchant[/url] / [url=http://pcpartpicker.com/p/RR0n/benchmarks/]Benchmarks[/url]
[b]CPU:[/b] [url=http://pcpartpicker.com/part/amd-cpu-hdz965fbgmbox]AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor[/url] ($94.99 @ Newegg)
[b]Motherboard:[/b] [url=http://pcpartpicker.com/part/asrock-motherboard-970extreme4]ASRock 970 EXTREME4 ATX AM3+ Motherboard[/url] ($99.99 @ Amazon)
[b]Memory:[/b] [url=http://pcpartpicker.com/part/gskill-memory-f31866c9d8gab]G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory[/url] ($64.99 @ Newegg)
[b]Storage:[/b] [url=http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex]Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive[/url] ($66.99 @ Amazon)
[b]Video Card:[/b] [url=http://pcpartpicker.com/part/sapphire-video-card-100358l]Sapphire Radeon HD 7770 GHz Edition 1GB Video Card[/url] ($99.99 @ Newegg)
[b]Case:[/b] [url=http://pcpartpicker.com/part/corsair-case-200r]Corsair 200R ATX Mid Tower Case[/url] ($49.99 @ Newegg)
[b]Power Supply:[/b] [url=http://pcpartpicker.com/part/corsair-power-supply-cx430]Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply[/url] ($34.99 @ Newegg)
[b]Total:[/b] $511.93
[i](Prices include shipping, taxes, and discounts when available.)[/i]
[i](Generated by PCPartPicker 2013-04-20 05:09 EDT-0400)[/i]
i have a dvd/ cd writer and another cd writer already
I would go for a HD 7770, even if it cost more, it is worth it.
pcpartpicker need to be a standard.
