Will this work for gaming?
I have a 480 watt psu and been thinking of buying a amd radeon 7770 card or a amd radeon 7850 card?? I am buying a better psu by the end of the month could the psu i have now last me tell then??
Can't really say without more information about your machine.
what other info u need?
What CPU are you using? Also, are you doing anything crazy with your hardware that might drive up your power usage?
cpu i just ordered is a amd phenom ii x4 955 black edition...and no thats it no crazy hardware just simple web browsing and gaming
Should be fine then. Why did you go with the 955 instead of the 965?
had to buy other components and the 955 was chaper then 965 ill upgrade my cpu at the end of the yr i just need something to play a few games for awhile
which gpu u recommend 7770 or 7850??
The 7850 is a nice card, but what manufacturer is the PSU from?
You do not want any cheap PSU to drive your PC.
whats some psu brands ghost?? i have a logisys psu is that any good?? i have a mid tower atx case
No, that is a terrible PSU.
Go for a Corsair/ Seasonic/ Silverstone/ XFX/ NZXT/ Enermax/ Antec/ LEPA/ FSP
