Will this run BF3 at Ultra settings @60FPS+?
Can anyone tell me if it will run BF3 ultra at 60+ fps?
NZXT Phantom 410
AMD FX 4170 @4.2Ghz
XFX 7850 GHZ Edtion @ 1.5 Ghz
ASUS M5A99FX PRO R2.0
16 GB G.Skill ARES-1866 RAM
CORSAIR Enthusiast Series TX750 V2 750W
Western Digital WD Blue WD10EZEX 1TB 7200 RPM
Cooler Master Hyper 212 EVO
COOLER MASTER QUICK FIRE TK
ASUS VH232H Glossy Black 23"
No, you'll get about 50 average on High settings accoding to tomshardware.
Anyway i could increase the amount of Fps i would get?
In Ultra and everything maxed out you will probably average out about 40-45 fps. Best way to get up to 60+ fps average would probably be to get a second 7850 in crossfire or if you can't find another xfx black edition since it is discontinued I would sell it and buy something like an hd 7970 and you could easily play 60 fps average on ultra in BF3.
There not discontinued http://www.newegg.com/Product/Product.aspx?Item=N82E16814150605
And i most likely will crossfire them
Nope, maybe around 45Fps if everything plays nice.
I do not think that is the "black edition" as you stated but you could still crossfire them just thought you wanted 2 of the same.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150607
Well i meant the GHZ edtion card thats the one i most recently bought. ill cross fire them at a lterdate and get about 95 FPS at 1920x1200
