Will this power supply work?
Will this
http://www.amazon.com/Corsair-Builder-Watt-EPS%C2%A0-CX600/dp/B0092ML0OC/ref=sr_1_2?s=electronics&ie=UTF8&qid=1390024200&sr=1-2&keywords=660w+power+supply
work with this motherboard
http://www.amazon.com/gp/product/B009FC3YJ8/ref=oh_details_o08_s00_i00?ie=UTF8&psc=1
Yes of course it will work.
But what else do you intend on using in the build? A full list of nominated parts will help determine if that psu is the right size for your requirements.
Well, yes. Most motherboards and such have standard power connectors so you won't be struggling to fit it.
It is more important about what parts you are going after and how much total power they may draw. For your system which I assume is meant to be an APU system, it's overkill. You could go to 430 watts if you want or 500 if you just plan on adding a decent GPU.
im adding evga's gtx 760
Most motherboard should support at least one GPU.
What CPU, MoBo, GPU, and PSU are you running?
