Will this power supply Work for this build?
CPU
AMD FX-8350 4.0GHz 8-Core Processor
Corsair H100i 77.0 CFM Liquid CPU Cooler
Motherboard
Asus Crosshair V Formula-Z ATX AM3+ Motherboard
Corsair Vengeance 16GB (4 x 4GB) DDR3-1866 Memory    Storage X2
Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive
x1
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card X2 SLI 2-way
EVGA GeForce GTX 770 2GB Superclocked ACX Video Card (2-Way SLI)
Raidmax Vampire ATX Full Tower Case                                   Power Supply
EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply
Optical Drive
Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer                      Operating System
 Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)                                Do you think this Power supply will work for all this?
yeah that EVGA 850W should be more then enough for sli 770´s.
You are totaly fine with that psu.
Thanks for commenting :D
AMD FX-8350 4.0GHz 8-Core Processor 15W - 125W
Corsair H100i 77.0 CFM Liquid CPU Cooler 10W - 15W
Asus Crosshair V Formula-Z ATX AM3+ Motherboard 17W - 70W
Corsair Vengeance 16GB (4 x 4GB) DDR3-1866 Memory 18W - 18W
Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive 1W - 5W
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive 4W - 20W
EVGA GeForce GTX 770 2GB Superclocked ACX Video Card 57W - 230W
Total: 180W - 718W        the case has a 140mm back fan and 200mm front fan this will be the completed build so don't want to under volt it xD
You can take those wattage calculations with a big grain of salt.
TDP doesnt tell anything about how much power a cpu consumes. Same counts for GPU´s.
But yeah is this a complete new build?
Because keep in mind that a FX8350 will bottleneck a GTX770 sli in cpu bound games, so idk which games you play mainaly?
http://www.guru3d.com/articles_pages/evga_geforce_gtx_770_sc_review,5.html
Yeah it is complete I'm just waiting for the 2nd GPU.  I mostly play minecraft with shader but will play skyrim moded fallout  moded  and play others.  how would it bottleneck the 770 sc?
in games like skyrim the FX8350 will bottleneck a GTX770.
But as soon as we speak about dual 770´s, then the bottleneck will realy be noticable.
If it was my money, then i would go with an 4690K and Msi Z97 gaming 5 mobo or something similar.
Skyrim is just one of those games that realy loves intels per core performance, and fast cache. Skyrim realy run's better on an intel chip.
And i say this as an FX8350 owner.
source: http://www.bit-tech.net/hardware/2013/06/12/intel-core-i5-4670k-haswell-cpu-review/5
Psu calculation websites tend to over estimate the power supply you need on purpose just encase you by a cheap brand, but as long as you buy a well known brand you should be fine and evga is one of them.
Pcpartpicker estimates tend to be better then any of them sites.
I will go Intel One day.  I wanted I7 4790K I think but it took me like 1 1/2 years to get this build. 1 peace at a time O.o  I got the CPU and MOB for like 600$ I think but mite be wrong at the time 4790 was like 600$.  I hope my setup will work tell that day.  Thank you for answering my Question's.  If  this helps with just the 770sc it seems so clean my monitor runs at 144Hz  1080p  vsync 144fps I have not notice any  performance issues.  I like it so much thought get two GPU it will be Crazy.  I will see I guess .
I can't tell which exact model that EVGA power supply is, but it should be plenty of wattage.
Kind of crap SSD, though.  Pick up something else if you haven't bought it yet.
