Will this power supply fit?
i am fixing a computer for my sisters friend the psu had a pin on the back break,so it is now a paper weight,it was a Bestec atx-1951d which is 5-7/8" wide, 4" deep, and 3 3/8" tall.
I found this one in newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16817338046 and it says it is 5.75" x 3.25" x 4"
Do you think it will fit?
the pc is an Hp pavilion 512n.
Both micro ATX PSUs so.... makes sense to me.
i was worried about the dimensions,you think the little bit that they are off won't matter?
The width and hight should be to the ATX standard, so maybe your measurements are a bit off?
i found the stock psu size on this site http://www.outletpc.com/pa4525.html
Don't know then. Can't you just return it if it doesn't fit?
[color=green]Just a reminder OP, post in 'Other Hardware' next time, not in the one you originally posted in.[/color]
Ok sorry about that.
