I'm building a budget gaming pc soon. Seeing as this is my first time building a computer, I want everything to work. I also can't afford to have it not work, so it's more of a need... anyway, here you go:
$37 - http://www.1stchoicememory.com/catalog/viewitem.asp?ID=29219&r=g&origin=product-search&kwd=&source=pla&gclid=CNjQjZ6T17QCFQUFnQodz3AA_g 450W power supply
$95 - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5692033&CatId=22 AMD Phenom II X4 965 Black Edition AM3 CPU HDZ965FBGMBOX - 3.40GHz, Socket AM3, 6MB Cache, 2000MHz (4000 MT/s) FSB, Retail, Processor with Fan
$130 - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7486106&CatId=7387 asus radeon hd 7770
$35 - http://www.frys.com/product/7275473?source=googleps&gclid=CMzFi7-n17QCFQU5nAodGBAAKA Patriot Viper 3 Red DDR3 8GB 1866MHz Dual (2x4GB) Modules PV38G186C9
$42 - http://www.aztekcomputers.com/CPA8818BK-DIABLOTEK-3776096.html Diablotek Abyss 10-bay Atx Mid Tower Window Gaming Case W/2x120mm Fans - No Psu (black) CPA-8818-BK
$60 - http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1511897&SRCCODE=WEBGOOPA&cm_mmc_o=mH4CjC7BBTkwCjCV1-CjCE&gclid=COP26OHm17QCFQ0GnQodxB4A6w ECS A55F-M2 AMD Hudson FM1 Motherboard
$68 - http://www.serversupply.com/products/part_search/pid_lookup.asp?pid=111495&gclid=CPvXyNrz0bQCFQeDnQodyBoA_A 1TB hard drive
(I'm not getting an optical drive because I can install Win. 7 on a flash drive)
