OK so I have this case :
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
I would like to now if this motherboard will fit in there:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157314
yes the mother board will fit in your case
Yes, it will fit just fine.
I have used that exact case in several build it will fit an ATX motherboard fine
yes it'll fit. If you read the description it tells you that the case is compatiable with Micro-ATX & ATX motherboards and your motherboard is ATX so yep it'll fit
