I'm using this cm 500w psu and I was wondering if i could use it in my build. I'll upgrade after a month to an xfx one. Thanks in advance. The cm psu is this one http://www.amazon.com/Cooler-Master-eXtreme-Supply-RS500-PCARD3-US/dp/B001G0WPLK/ref=sr_1_1?ie=UTF8&qid=1383011511&sr=8-1&keywords=coolermaster+psu
Maybe coolermaster make some fairly crappy psu's.
This is there more expensive 'Gamer Xtreme' psu.....hardly 'quality' (Cooler Master GX 650W)
I just want it to last for at most a month. Can it last that long?
only has 1 6-pin pcie...if it has the ports, it should be fine for a temporary psu
jesus christ, that's a shitton of solder...
Well it will work just dont keep it for long :) the XFX are nice psu's for the price.
Thay are seasonic psu's in a new dress.
Will do. I will get a new psu asap :)
