So I am doing a build for a friend, he wants to have the zalman z11 case. I am putting a 4670K into it and I am wondering if I will be able to fit a thermalright silver arrow S-BE into it, I think the height of the silver arrow is 16.5cm, but I would like to know if it will actually fit before I buy it and possibly get a nasty surprise of it not fitting.
Also if anyone knows to maximum height cpu cooler the z11 plus can take would be helpful incase I decide to get a different cooler if budget changes etc.
Any help will be much appreciated!
Uh, I looked at that review and scrolled down, there is a nh-d14 installed in one of the pictures, I may be wrong but I am pretty sure the silver arrow is around the same size or smaller than that, anyone know about the max height cpu cooler that can fit into a z11 plus?
That case is (about) 10.5 inches wide. The cooler is 6.43701 Inches tall. Thats about 4 inches of space for the backplate, motherboard, and cable management area. It should fit.
Plus, it looks to have a little extra room on the sidepanel just for the cpu cooler.
Thanks, I thought it would probably fit, just wanted to make sure.
