Will this build work?
Need help with this.
Feel free to share your views on this build.
I'm on a tight budget here in Singapore, about SG$1000.
Will this build work? Do I need to get anything else?
I don't need it to overclock.
Just play games well and able to
handle photoshop or any adobe creative suite products well.
CPU - Intel Core i5 3470
Motherboard: MSI B75IA-E33
Memory: Corsair Vengeance Pro 4gbx2
GPU: Sapphire 7850 2GB OC
PSU: FSP Raider 550W 80+ Silver
Case: Bitfenix Prodigy
Storage: Plextor M5S 128gb SSD
Why are you going with Corsair Vengeance Pro for a budget build? Go with normal vengeance or g.skill ripjaws,
Ahh, my bad. It's only $5 difference so I thought might as well.
So just getting the Corsair Vengeance Low Profile is enough?
._. Its better to get low profile.
Alright, thanks for the info, bro. Any problems with the other parts?
I wouldnt go miniITX. Just trust me, don't. Theres no room for decent upgrades. It just sucks. I've owned a bitfenix prodigy its nothing too great and it sucked when it wasnt good for upgades.
http://pcpartpicker.com/p/1d9j6
I made this, its a lot better. Not sure if you can afford it but take a look.
Thanks for build suggestion.
Thing is, I'm from Singapore and I can't get some of the parts. :l
Unless you want to help me check this pricelist here and recommend me another build?
http://www.fuwell.com.sg/uploads/misc/Fuwell040713.pdf
