Also, can I do better with about the same price?
I already bought the APU and i can't change that.
A8-5800K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113280
CASE:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811144196
PSU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
RAM:
I heard that you need good ram for the IGP on the 5800k so could anyone recommend 2x4gb for under 50 dollars?
i think i want this though http://www.newegg.com/Product/Product.aspx?Item=N82E16820231550
MOBO:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157333
