Will a AMD Athlon II x4 760k bottle neck a AMD r9 280x?
For gaming it may depend on whether or not the title is cpu heavy but I use something fairly similar to this no problem, I guess what games are you playing?
Counterstrike GO, tomb raider, Day Z, Skyrim, Arma 2, Battlefield 4 (when i get it), and some mmorpgs
I would say the only stressing game would be skyrim which has a reputation for working better on intel chips anyway, but with that selection that processor would seem fine and the gfx card seems fine too. I'm not even going to comment about BF4 though.
Haha, okay thanks
You should know most MMORPGs along with Skyrim work much better on Intel chips as they are largely single threaded. You would see much better performance on those sort of games with an i3. On Battlefield 4 I'm not a hundred percent sure. The single-player portion of BF4 barely uses the CPU at all and you see identical fps on a 750K as a 3960X, but multiplayer is a whole different ballgame.
Yes, it probably will bottleneck somewhat, but not by a huge amount. Your best option would be to get an FM2+ motherboard and the 750K. Then you can overclock the CPU if needed (you should be able to get the 750K to about 4.3GHz), or grab a Kaveri chip once they're released, hopefully they release a Kaveri Athlon which from what we've heard should be about 30% faster than Piledriver, so that would be a huge increase to performance for hopefully under $120. Having a bottleneck isn't the end of the world, it just means that when you finally do upgrade the CPU, the GPU will be even better =)
All in all it should be fine for pretty much all those games. It might struggle just a little on BF4, and on MMOs just note that you won't get amazing performance even if you got an FX 8350 since most are single-threaded (e.g. Rift, World of Warcraft, Guild Wars 2). Don't get me wrong, you'll be able to play them fairly well at relatively high settings, but to max these games out you pretty much need an Intel CPU or one hell of an overclock :P
Cheers, you've given me alot of information and more to consider:)
At stock speeds there is a chance, but if you overclock it(should hit 4.5ghz easy) then I highly doubt it unless its like skyrim and only uses 2 cores.
