I am building my first pc and want to play Bf3 and Arma 2 on low settings. Will this get the job done?
HIS Radeon HD 7850 IceQ X H785QN1G2M Video Card - 1GB GDDR5, PCI-Express 3.0(x16), 1x Dual-Link DVI-I, 1x HDMI, 2x Mini DisplayPort, DirectX 11, Dual-Slot, Fan
195.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7371357&CatId=7387
AMD FD4130FRGUBOX FX-4130 Processor - Quad Core, 8MB L3 Cache, 4MB L2 Cache, 3.8GHz (3.9GHz Max Turbo), Socket AM3+, 125W, Fan, Unlocked, Retail
$109.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4283004&CatId=1946
GIGABYTE GA-970A-DS3 AMD 970/SB950 AM3+ FX ATX Motherboard - ATX, Socket AM3+, AMD 970 Chipset, 2000MHz DDR3 (O.C.),
SATA 6.0 Gb/s, RAID, 7.1-CH Audio, Gigabit LAN, USB 3.0, CrossFireX Ready
64.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2932738&CatId=7248
Ultra LSP650 650-Watt Power Supply - ATX, SATA-Ready, SLI-Ready, 135mm Fan, Lifetime Warranty w/ Registration
54.99
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=3276573
Corsair Vengeance CMZ8GX3M2A1600C9B Desktop Memory Kit - 8GB (2x 4GB), PC3-12800, DDR3-1600MHz, 9-9-9-24 CAS Latency, Intel XMP Ready, Unbuffered
49.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=40739&CatId=4534
Ultra XBlaster Mid-Tower V2 Case - ATX, MicroATX, USB 2.0, Audio, 6x 3.5" Bays, 4x 5.25" Bays, 7x PCI Slots, Lifetime Warranty with Registration
19.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1636710&CatId=1842
WD Blue WD5000AAKX 500GB Desktop Hard Drive - 3.5", SATA, 7200RPM, 16MB Cache
49.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7281716&CatId=2459
Samsung SH-224BB/BEBE Internal 24X DVD Burner -Tray, SATA, 1.5MB Buffer Memory, 16x DVD-R Read, 48x CD-R Write (OEM)
16.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4814646&CatId=89
TOTAL 602.94
