I wan't to make a build with a Bitfenix prodigy M, but not sure if parts will fit in it.
About the build: Have been using this for about 1 year now.
Also, I don't know if an Cooler Master Hype 212 Evo will fit in this kind of build, been searching a little but have read different things. And it kinda looks like It won't fit because of the 4 ram cards.
I don't really know that much about the Bitfenix prodigy M, since I haven't found any very good build videos.
Right now I have around 500$ I can spend for new parts for my build. Please come with tips and parts that would work with this build :D Sorry if what I wrote here was a confusing, bad grammars or things like that. From Norway and my English isn't that great
In response to your OEM key - you can use it as many times as you like - may have to call the activation line. Do a fresh install preferably or use OS migration software (samsung ssd's come with a very easy to use application, that is fool proof). Also use the WD blue over the seagate for the OS if it comes to that, a ssd is the way to go.
CM 212 will fit as your ram is only slightly bigger than naked dimms,
Reviews that will give you a good idea on the case >
