I am about to build a new pc and need to know if these parts are all compatible...
http://pcpartpicker.com/p/2gFXi
and also please don't tell me to change anything unless it is not compatible because i have decided on these parts... i do intend on upgrading the cpu in the new year
THANKS :D
The parts that you chose are very unbalanced, you have bottlenecs all over the place, here is a list that i would recommend:
CPU: Intel Core i5-3470S
MOBO: Asus P8Z77-M Pro
MEM: G.Skill Sniper 8GB (2 x 4 GB) DDR3-1600 Memory
Storage: Seagate ST1000DM003
VIDEO: EVGA GeForce GTX 660 2GB Video Card
POWER: Corsair CX750M
CASE: NZXT Phantom 410 (Red) ATX Mid Tower Case
DVD: Lite-On iHDS118-04 DVD/CD Drive
Beside that this system is more expensive, it will be better suited for your needs. And instead of upgrading a new CPU later you can upgrade to a second GPU for better performance. Also your CPU will be better suited for gaming and also will eventually use the same amound of power as the Pentium.
http://pcpartpicker.com/p/2hvsR
I've seen this build. Sure, they're compatible. Everything will work.
Doesn't mean that it'll work well for the money. It'll be pretty crappy tbh.
guys i don't have enough money to go with your option..:( but if i get some money after christmas could i then upgrade to an i5 cpu without any problems???
