This is my first build and having no experience putting together computers and choosing compatible parts I would appreciate some help making sure the parts are compatible.
Here is what I have come up with.
http://pcpartpicker.com/p/3ypIc
Thx
Thx
Should work.
AMD Build: http://pcpartpicker.com/p/3yqYP
Intel Build: http://pcpartpicker.com/p/3yr5t
I'd explore your options for speakers and keyboards. Also if you're spending $1000+ on a PC setup you might as well get an IPS monitor. I'd also investigate the viability of a powerline setup rather than wifi, as it can be more reliable than wifi.
they will be compatible, and it is a pretty solid build :) only thing what i might consider changing is the psu, even a 550W psu will do the job, but on the other hand, it is good to have spare watts for guture upgrades etc.
Also, consider getting a SSD, it will speed the boot and loading times a LOT. Something like samsung 840 evo, Kingston hyperX 3k or A-Data XPG 900 would be my suggestions, they are all well tested and perform extremely well :)
Thx I really appreciate the help .
