This is my first pc build and I'm going for a low cost gaming rig. I wanted to know if there might be any compatibility issues with the parts, or if anyone has any recommendations. Thanks!
Motherboard: GIGABYTE GA-970A-D3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard http://www.amazon.com/GIGABYTE-GA-970A-D3-AM3-SATA-Motherboard/dp/B0056G10WK/ref=pd_ts_zgc_e_1048424_5?ie=UTF8&s=electronics&pf_rd_p=1473612722&pf_rd_s=right-5&pf_rd_t=101&pf_rd_i=193870011&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0T3MMM6ECSTPN393NYB2
CPU: AMD Athlon II X3 455 Processor (ADX455WFGMBOX) http://www.amazon.com/AMD-Athlon-455-Processor-ADX455WFGMBOX/dp/B003N1A5W6/ref=dp_ob_title_ce
Core cooler: Cooler Master Hyper 212 Plus - CPU Cooler with 4 Direct Contact Heat Pipes (RR-B10-212P-G1) http://www.amazon.com/Cooler-Master-Hyper-Plus-RR-B10-212P-G1/dp/B002G1YPH0/ref=sr_1_2?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1360963704&sr=1-2 will this work with my processor? It has a AM3 mount but the Athlon is not listed
GPU: Sapphire Radeon Vapor-X HD 7770 GHZ OC 1 GB DDR5 DVI-I/DVI-D/HDMI/DP PCI-Express Graphics Card (11201-05-20G) http://www.amazon.com/Sapphire-Vapor-X-PCI-Express-Graphics-11201-05-20G/dp/B00861BB0S/ref=sr_1_7?s=pc&ie=UTF8&qid=1360961880&sr=1-7&keywords=sapphire
RAM: Kingston Technology HyperX 8 GB (2x4 GB Modules) 1600 MHz DDR3 Dual Channel Kit (PC3 12800) 240-Pin SDRAM KHX1600C9D3K2/8GX http://www.amazon.com/Kingston-Technology-Modules-KHX1600C9D3K2-8GX/dp/B0037TO5C0/ref=sr_1_8?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1360961620&sr=1-8
Power supply: Corsair Builder Series CX 430 Watt ATX/EPS 80 PLUS (CX430) http://www.amazon.com/Kingston-Technology-Modules-KHX1600C9D3K2-8GX/dp/B0037TO5C0/ref=sr_1_8?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1360961620&sr=1-8
Hard drives and SSDs: Kingston HyperX 3K 90 GB SATA III 2.5-Inch 6.0 Gb/s Solid State Drive SH103S3/90G http://www.amazon.com/Kingston-HyperX-2-5-Inch-SH103S3-120G/dp/B007R67FNA/ref=sr_1_2?m=ATVPDKIKX0DER&s=electronics&ie=UTF8&qid=1360963106&sr=1-2
Western Digital Caviar Blue 500 GB SATA III 7200 RPM 16 MB Cache Bulk/OEM Desktop Hard Drive - WD5000AAKX http://www.amazon.com/Western-Digital-Caviar-Cache-Desktop/dp/B00461G3MS/ref=sr_1_7?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1360963256&sr=1-7
Case: GAMMA Classic Series ATX Mid Tower Interior Steel Chassis (Black) http://www.amazon.com/GAMMA-Classic-Interior-Chassis-Black/dp/B002UDK9U6/ref=sr_1_9?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1360963392&sr=1-9
Case fans: (6x) COOLER MASTER SickleFlow 120 R4-L2R-20AR-R1 120mm Silent operation Red LED case fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103091
