Will a Zerotherm Nirvana fit in a Thermaltake Soprano, I have the one with a window if that makes any difference.
it will fit. its not a tall cooler. but it mite hit ur psu, or ur northbridge heatsink. cause its a wide cpu cooler.
If you wanna make sure go for the Zerotherm BTF92 Overclockers edition. its all copper, same price, smaller, around same noise level
Im using a XFX 680i LT SLi so the northbridge cooler isnt that big
how tall is it?
