I have several 4K monitors, and am planning on using an L1T KVM to switch between my main PC and work laptop. Some of the monitors are >144hz & HDR, so I would love the extra overhead of DP2.0/2.1. I’m also just very excited to consolidate everything on one USB4 cable.
Are there any plans in the works for updating the DisplayPort version in the KVMs? I thought it’d be simpler than the HDMI ones since there’s less licencing/EDID faff, but I could be totally wrong.
Any closer? Living with an Odyssey G9 57" for almost 2 years now, with only one DP 2.1 input, with multiple MacBook Pros to connect, has been a level of hell. HDMI 2.1 only works through the dedicated HDMI ports on these laptops, and they are all extremely faulty, almost never providing full resolution. I need to get this DP port switching already.
I am using the following with first m y FO32U2P and now my LG-39GX950B UHBR20 does work at both 240hz and 160hz - though super sensitive on the LG to cable lengths, had to keep them short, would love a KVM with updated retimers/EDID and even better USB-20 or USB-40
Item #
Description
Qty
SQ6079757
1.4 Display Port KVM Switch - Triple Monitor - Two Compute
