Will PSU work with other components?
I know this is based off Logan's $600 (US) build but I changed a few things. The reason the CPU and Motherboard are edited/ cheaper is because of a Microcenter bundle. The price is $140 for both of them.
I would like to know if the case will fit all the components and if the PSU will support all of it or should I get a different one. Thanks!!!!!!
http://pcpartpicker.com/user/Jerboa4444/saved/3pdv
you could even trow in a XFX pro 550W psu 80+ bronze decent, and realy cheap. 550W more then enough for a single gpu setup.
or if you like modular a corsair CX builder series.
Do either of these have really easy cable management and are able to support future upgrades? Thanks
the XFX is not modular, so its not the best cable management option. but the corsair builders series CX600M or so, are semi modular, so thats a bit easier to work with the cable routing, anyway which upgrades are you talking about?
If you ever plan an cpu upgrade please take a better motherboard then.
CX Series CX750M 750 Watt ATX Modular Power Supply is on sale with rebate at microcenter.
Should I pick it up?
It's originally $85 and it's on sale for $65 which is just a few dollars more than the original EVGA psu.
Jerboa no one can tell you for sure until you reveal your requirements.  The CX750M (744 W actual) is not a bad product but it's rated at 30*C instead of 40*C and it's not made as well as others.
Like MisteryAngel said, what are your upgrade plans.
Ok. I guess I would like to be able to change any of my parts and not have to worry about the psu. This is going to be my first build so I don't know a lot about what the advantages of an expensive psu are and what advantages do expensive motherboards have.
I guess I want to know: Can my current build last a few years? With the current build, what is the best psu around $80  - preferably modular
thanks!!
well a decent 550 / 650W psu is more then enough for  a single gpu setup, but if you ever plan on a CF or sli, (which i personaly not a big fan of), then its better to grab a 750W or better. But i personaly prefer single gpu setups.
About the motherboard, if you want a upgrade way to a AMD 8 core FX cpu, i would recommend to pickup a better board, the msi isn´t realy a great board definitely not designed for a amd 8 core cpu, if you can afford a Asus M5A99FX pro R2.0 mobo, then i would grab that, its a bit more expensive, but you will have a decent upgrade way to an FX 8 core.
if you dont care about an FX 8 core then go with the Asus M5A97 R2.0 motherboard.
+1.
Cable management with a non-modular PSU isn't that bad.  I put my XFX Pro550w PSU into an ITX case relatively neatly.  Modular PSUs are still nice, though.
Another +1 here.  For changing to better components later, 550 is enough as long as one graphics card is installed, not two.  In that case around $80 I can again recommend Seasonic G 550, or Ksajal found the S12G 550.  Both are excellent (they are the same, internally).
I think the Seasonic G 550 is a good way to go. I think I heard Logan say it was a very good brand. Thanks all!
Seasonic is always a good choice. They make XFX units, but the G550 is one of the best units for your needs.
Anything seasonic is pretty much guaranteed to be excellent.
I would like to know what PSU to get for this build: http://pcpartpicker.com/user/Jerboa4444/saved/3tpE
CORSAIR CXM series CX750M 750W for $69.99 after $20.00 rebate from Newegg
or
SeaSonic SSR-550RM 550W for 89.99
Which is quieter and more reliable?
Seasonic is of higher quality compared to the Corsair CX series.  That build will run just fine on 550w.  This PSU is usually more reliable.
If you don't mind doing the mail in rebate, the CX750M will only run at around 50% load during max usage, and the fan won't have to spin up as much either.  This PSU would probably be quieter.
I agree, the Seasonic unit is probably much more reliable.  It's gold rated and is reviewed as having high quality internals and will likely last longer.  The CX750 is actually a better design than the other CX, but it's still rated at 30*C.
I think both PSU's will work fine and both will be quiet.  Remember the Seasonic is more efficient and will be dissipating less heat.
I see nothing wrong with the CX750M but if it were me I would buy the G 550 every time because I believe it's better made and better specced, based on the jonnyguru.com review.  (Probably this is a good time to admit I have a CX500M which I got cheap, that was before I started reading up on power electronics.)
I will go with the Seasonic PSU. Thanks!
Don't worry, I had a Cooler Master eXtreme Power Plus that was running at like 70% efficiency lol.
Changed that sucker out for an XFX Core Ed Pro550w (Seasonic M12II rebrand, non modular) and now my pc runs nice and cool.
