Will PSU be okay? Plz Help!
So in about a month I will be getting another 7870xt and I will be putting them in crossfire. I have an OCZ 650W fully modular psu and I'm not sure if it will be sufficient enough until Christmas when I can get a different psu. Plz help!
My build-AMD 6350 at stock clock 6 core.
ASUS 990fx Gen.3 R2.0 Mobo
8Gb of gskill ripjaws x series at stock clock.
2 7870xt at stock clock
1tbwd caviar black
Asus idk what model optical drive
OCZ 650w fully modular power supply
Will this be okay until December?
http://support.asus.com/powersupply.aspx
In short, no
it should do the job but dont do any more.
If it has a good efficiency rating, it should be enough. Check to see if it is gold rated, or anything bronze and above.
is that a OCZ modstreampro? I read some reviews where it would fail at full load (650W)
650 watt should be enough but I'm afraid the PSU doesnt have a good reputation..
No it's not
Its Bronze
