Will my system be good "enough" for bitcoin
So the title said the just of it, but I want to know if my system is big enough for bitcoin "litcoin" or other coin with my system as is. also as a side note, what coin would you recommend for my system as is.
specs are current:
AMD athlon II x4 model 640 at 3ghz
ASUS m4n am3 mobo
8g's ram at 1833 CL 9
MSI twinfrozer HD 7850 2g card
1T hdd
600w mod extreem pro 80+ bronze psu from OCZ
win7 hp
note for connection speed, 33 avg down with 10 up on about a 15 ms ping
Maybe you make a few milli-BTC in a mining pool, but unless you're running ASICs, you likely won't recoup the cost of electricity.
That wont even mine Litecoin effectively, actually.
Its all about the GPU.
I get that it's all about the GPU, but as long as it's possible it's worth a shot
7850's have shown some pretty good ltc hashrates, better than my 7870
according to the https://litecoin.info/Mining_hardware_comparison website, you will MAX out, if you're lucky, at 411KH/s.
according to http://www.litecoinminingcalculator.com/ , if you mine constantly, 24 hours a day, you will receive 0.1 LTC / Day, with a 1% pool fee.
each litecoin is hovering at 23 dollars per coin as of now. That means that you will make $2.30 a day, constantly mining.
It's up to you if you think its worth it to have NO use of your PC, AT ALL, for 2.30 a day.
