Will my FX-4100 Bottleneck
hello i have an AMD FX-4100 and i just bought a R9 270x and i want to know if it will bottleneck?
It depends of what you do, the games you play... but if you can, grab a 6300 it  would be a good upgrade
Go ahead and type on youtube   "Jayztwocents How to bottleneck"
It all depends on the games you play.  But for most AAA, yes you will bottlneck.  Single threaded performance is fucking garbage, and multi threaded is still crap
I had a 4170 literally a few days ago and it bottle necked my 560ti on BF4 to the point where my gpu was only being used 60% and my CPU was 90%+..... So yer it probably will in more demanding games.
Yes but luckily you can get your hands on a AMD FX 6300 and that should help with the bottle necking.
