A place to Post your specs to see if your computer will run these games
Giant toaster?
dafaq
http://pcpartpicker.com/p/vdJK
Im curious AF
There is always googling "Can You Run It" nice lil application.
Just an FYI, this post made no sense. But if you're looking for advice on the setup.
Less on a case, and spend more and switch to an AMD 6300 and 990 motherboard.
Arma 2 will take as much processor as you can give it (except hyperthreading, that has a negative effect). Save some money on that case (you can easily find one for 50 bucks less that will do the job, NZXT Tempest 410 is what I'd recommend), and switch the Extreme4 for the Pro4, or even cheaper, that's another 20 bucks. with the money you save, grab a quad-core i5. That video card is plenty, though you can get a 7870 for cheaper than that Asus. Personally, I'd save 10 bucks and grab the MSI Hawk Edition.
How well will this pc run it?
HIS Radeon HD 7850 IceQ X H785QN1G2M Video Card - 1GB GDDR5
AMD FD4130FRGUBOX FX-4130 Processor - Quad Core, 8MB L3 Cache, 4MB L2 Cache, 3.8GHz
8gb's of 1600mhz RAM.
You spent more on your case than you CPU...
