Looking to build a computer for Christmas, and I'm a bit worried about it not fitting in the case that I've chosen.
Of course I'm English so I have a budget of about £600, however my Birthday is 60 days after so I can get things that I don't have the money for, I don't expect this to be a problem because I get more from family and also I have a few pounds saved.
My system that I would like to build will be listed below, but I will be open for suggestions, Thank you.
System;
Motherboard: http://www.amazon.co.uk/Asus-M5A78L-M-USB3-Motherboard-Socket/dp/B0054U7HIO/ref=pd_sim_computers_27?ie=UTF8&refRID=06G1MNGA88F6TZ6MAPK6#productDetails
CPU: http://www.amazon.co.uk/AMD-FX8350-Edition-Processor-4-2GHz/dp/B009O7YUF6/ref=pd_sim_computers_4?ie=UTF8&refRID=1MJP9ZKNV1QBP1JTKQ97
RAM: http://www.amazon.co.uk/Corsair-CMZ8GX3M2A1866C9B-Vengeance-Performance-Desktop/dp/B0056VO2HK/ref=sr_1_34?ie=UTF8&qid=1407013411&sr=8-34&keywords=8gb+ram
GPU: http://www.amazon.co.uk/Nvidia-GeForce-Graphics-GDDR5-PCI-Express/dp/B00ICUGOP0/ref=sr_1_1?s=computers&ie=UTF8&qid=1407019249&sr=1-1&keywords=Asus+Nvidia+GeForce+GTX+750+Ti+Graphics+Card+%282GB%2C+GDDR5%2C+PCI-Express+3.0%29
SSD: http://www.amazon.co.uk/Samsung-250GB-Basic-Solid-State/dp/B00E391OX6/ref=sr_1_1?ie=UTF8&qid=1407024130&sr=8-1&keywords=250gb+ssd
Case: http://www.amazon.co.uk/Zalman-Z11-Plus-Installation-Anti-Vibration/dp/B007C008L2/ref=sr_1_1?ie=UTF8&qid=1407186860&sr=8-1&keywords=z11
CPU Cooler: http://www.amazon.co.uk/Cooler-Master-Seidon-120V-RL-S12V-24PK-R1/dp/B00D4EF734/ref=sr_1_1?s=computers&ie=UTF8&qid=1407021045&sr=1-1&keywords=cpu+water+cooler
PSU: http://www.amazon.co.uk/Corsair-Builder-Series-Modular-Certified/dp/B00ALYOTTI/ref=sr_1_1?ie=UTF8&qid=1407023681&sr=8-1&keywords=corsair+psu
Hard Drive: http://www.amazon.co.uk/WD-Desktop-SATA-Drive-Green/dp/B008YAHW6I/ref=sr_1_1?s=computers&ie=UTF8&qid=1407112261&sr=1-1&keywords=internal+hard+drive+2tb
So will this all fit, and will the motherboard work and what would people recommend?
Thanks, pxseidxn.
