Will I bottleneck?
I have a AMD 64 x2 4800, my question is will that bottleneck a 9800gtx+?
ghz?
i do not overclock, so it should be stock clocked
ye i think so my 5000+ black edtion was bottel necked my 9800gtx at stock settings
fak-eth
i didn't ask if you overclocked, i asked how fast your processor runs.
2.5GHz
i personally think you should be fine. if you must, just overclock it close to 3ghz. the 9800gtx+ isn't that powerful.
okay, thnx for the knowledge
I use a 3870X2 at Core - 865MHz Overclocked passed factory overclock (LOLWUT) and 1882MHz Memory clock
and my cpu is a amd 6000+ at 3.0ghz i feel its bottle necked
ye if it does bottleneck i cant imagine it would be an epic one
at 2.5 it will be bottle necked some.. its pretty hard to get a way from bottle necking my q6600 is at 3 ghz and i feel it is a little but 3ghz seems to be a good number to try and get to.
it will bottleneck.
an amd 5400+ black edition bottlenecks an 8800gt.
