Will Crossfire work?
I want to know if I can crossfire two AMD Radeon HD 7770 on these two builds.
Also build 2 is a friends who lives about 120 miles away. So I can't take the GPU out to test it.
Build 1:
 Motherboard:
Gigabyte 970A-UD3
GPU:
AMD Radeon HD 7770
PSU:
Seasonic 630w
Build 2:
Motherboard:
Asrock A780GXE/128M
GPU:
AMD Radeon HD 7770
PSU:
Ocz 700w
just.........
I know what you are saying. Take one GPU from the other and try it. Well one is a friends who lives 120 miles away. I am not going to drive that distance.
Yes both boards support it.
http://www.gigabyte.us/products/product-page.aspx?pid=3907#ov
http://www.asrock.com/mb/AMD/A780GXE128M/
What scares is it does not say (AMD Radeon HD 7770)
ex. http://www.asrock.com/mb/AMD/A780GXE128M/?cat=VGA&c=CF
Yea don't get the asrock the last BIOS update was in 2010. Get the Gigabyte one it will deff support it.
My friend has the asrock, I have the gigabyte.
So then just get the other 7770 if thats your question now.
