I am a fire fox user and I am running windows 7, using cross fired 7950's and a fx8350, I have had mess around with the setting flash player 11.6 just to get it running stable. Do anyone know how to fix it permatly, or when amd or adobe are going to fix it.
I had the same problems with it, so did my friend and he has an nvidia card I don't think that it has to do anything with the card. My friend started using waterfox (64bit firefox) and the problem was gone and mine just stopped bugging.
I will try that
Thank you
update, it works
Thank you again
