Will a Radeon HD 7870 2GB GDDR5 Run it?
Hey. Just need some info and your opinions on this.
Will a Radeon HD 7870 2GB Run Battlefield 4 on Ultra, Or close to Ultra on 1920x1080p?
Its the most I can afford now, until I save up for GTX 770 or 760.
Heres a Link to the actual card:
http://www.ebay.com.au/itm/261059217952?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
My Pc specs:
Operating System: Windows 8.1 64-bit (6.3, Build 9600) (9600.winblue_gdr.130913-2141)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire M3985
BIOS: P11-A0
Processor: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
Memory: 16384MB RAM
Available OS Memory: 16320MB RAM
Page File: 3548MB used, 15716MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 11
My Current Graphics card is a GT 640. Very outdated :(
Thanks Community :)
Yes, it will run fine at 1080p ultra preset, the only thing you will not be able to max is the resolution scale, leave it at the default 100%.
BTW, buy a r9 270x, it's more powerful and it's around the same price and if you plan on buying  a graphics card later, don't go for anything lower than 780/290x, just add another 270x.
1080p at ultra will be fine, but you'll have to turn AA down quite a bit.
Have the same GPU but with factory OC and it ran Battlefield 3 completely maxed out averaging around 50 fps. I don't think it will be able to go all out with BF4 but toning down things like AA will allow it to run well.
