Will A Graphics Card Fix It?
So I have an AMD A10-5800k with no actual graphics card and the VGA connector was bent and no longer gives video signal. I am assuming that this is due to the motherboard not having functional ports, so I was wondering whether or not getting a graphics card and plugging my monitor directly into the graphics card would work, as supposed to getting a new motherboard.
Not only should that work, but you'll also get much better video performance out of your computer.  However, that's assuming it's due to a faulty VGA connector, and not a more serious issue.
Yes, if thats is the problem a video card will ix the problem......got a budget as im sure we can recommend a few good options for you.
Beautiful to hear, and I very much appreciate the response time of this community whenever I have an inquiry.
My budget is $100-$200 USD and I have a couple in mind. The R9 270x, 7870, or the 2GB GDDR5 GTX 660. Any more recommendations would be appreciated but looking at the statistics these are as good as it seems to get in the price range to me.
If you want to save a little money you could always get an R9 270, since its basically a slightly underclocked 270x and just raise the clocks.  Though I'd be personally hard pressed to recommend anyone get an AMD GPU right now due to the ridiculous cryptocurrency fad driving the prices sky high.
I would second this option.  If you can find a reasonably priced AMD R9, I'd go for that (and again, I would avoid the x skus as they're pretty much identical cards)
All the AMD R9 270 - 270x graphic cards are like 200-280 really. I mean besides the Powercolor R9 270x, Asus R9 270, and the Visiontek R9 270x. Judging by the looks of the graphics cards themselves, I kind of doubt the trustworthiness of Visiontek and Powercolor. I might be looking for GTX 660's as those are very close in price with a slight upgrade in each card worth $10 more than the last. Nvidia looks like it's winning the auction for me.
