Will a corsair h100 fit in a Thermaltake Commander Black ATX Mid Tower Case
im going to buy the part tonight and i want to make sure it will fit in the case
Doesn't look like it will fit, there is not enough clearence at the top.
what about a Zalman Z11 Plus Mid Tower ATXwould it fit
nope
look at something from corsair.
Same price as the Zalman http://www.newegg.com/Product/Product.aspx?Item=N82E16811139011
would this case work i realy waunt a side window i cant spend more then 90$ case
Same case with window. http://www.newegg.com/Product/Product.aspx?Item=N82E16811139016
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146081  ($59no window)
and  http://www.newegg.com/Product/Product.aspx?Item=N82E16811146080 ($69window)
