i think it will Cooler Master Haf 932 Advanced Full Tower also is it a good case
looking at the top from this video: https://www.youtube.com/watch?v=na0KKbtA1Ns he says you can install two 120's at the top now idk about space considering sometimes heat sinks from your motherboard maybe in the way or something but if you havent already bought it i would try looking at the h100i extra fan controling as well as a very nice light feature as well as cosair link which you can control everything from your desktop
yaah i alredy have the corsair h00i but the case i bought dident fit it so im hoping this one would fit since it a full tower
I'm pretty sure the HAF 932 was actually designed to be able to take 240mm or even 360mm radiators.
yes it loks to me like it should fit i have a switch 810 and have plenty of room
