Hello guys, this is my first post in here :-)
so i bought this ASUS GTX 560 non ti vga
my current specs are :
Core 2 due e6550 2.33ghz
Kingston Technology HyperX Blu 4GB 1333MHz DDR3
EVO 212 cooler
and the Asus gtx 560 non ti
im totally unhappy with the performance im getting in games BF3,MW3,CS:GO...etc
obviously its the cpu bottlenecking the vga. so i was wondering , can the Core2Quad q8300 or q8400 catch up with the VGA ?
and if you have something else to recommend i'd really appreciate it . Thanks :-)
Most likly even with either of those quads they will bottle neck you gpu,cause i had a Core2Quad q9450 4gb of ddr2 1066mhz and i was running a GTX 460 SE,andwhen i had upgraded my cpu(8150),MOBO(sabertooth 990fx),ram(8gb of ddr3 1600mhz),and my fps doubled on some games like Dirt 3.
i've been reading alot of comments saying that the gpu will work at its best with a quad core cpu "i5 2500K" but some of them said if you cant afford a new mobo+cpu
you should get the core2quad since its 775LGA / Quad core / and can be overclocked to 3.2+
and the kind of bottlenecking im having with this core2due 2.3ghz is just awful .. in CS:GO im getting like 40 fps out of 300 on low settings (same exact performance is the old crappy Geforce 210)
but you're q9450 is pretty good if it still bottlenecks your gpu then i totally need to upgrade the mobo/cpu. ... its gonna take a while -_-'
what is your budget for an upgrade? Cause i can try and see if i can come up with a good upgrade for the money.
Ok i came up with a few options.
Intel:
Intel Pentium G2120 Ivy Bridge 3.1GHz LGA 1155 Dual-Core Desktop Processor BX80637G2120
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116777
Kingston HyperX Blu 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104206
MSI B75MA-P45 LGA 1155 Intel B75 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130655
$194.97 before shipping
AMD:
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
MSI 760GM-E51 (FX) AM3+ AMD 760G HDMI Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130634
$179.97 before shipping
Also to help you decide here are some benchmarks of the amd cpu agianist a slower intel cpu.
http://www.anandtech.com/bench/Product/102?vs=404
http://www.youtube.com/watch?v=6mxOc2P1ju8&hd=1&t=6m27s
thanks guys, that was helpful .. one more thing
isnt my current ram okay ? or it needs an upgrade to?
Kingston Technology HyperX Blu 4GB 1333MHz DDR3.
it's not bad,but i would suggest pick more of it so you have 8gb instead of 4gb.
see if you can run both your ram and the ram I picked at 1600 9-9-9 I'd run them at 1.65-1.70v or run them both at 1333 at 8-8-8
so you would have 8GB dual channel 1600
