Wii Sensor to USB Adapters
Bought a Wii sensor bar for emulating, only to find out it uses a proprietary connector. Is there an adapter for this, or do I have to buy one from scratch that uses USB?
It’s just an infra-red light so if you can find out what voltage it needs you can run it off anything, an adapter would dave you having to cut the connector off.
Yeah you’ll want to buy a usb bar
I’m a pinch you can actually use candles
